Nvidia_ATI
- Oct 5, 2011
I plan to install a H100i in the top of my CM Storm Stryker along with a pair of ugly NF-F12s. My question is what would be the best/optimal fan setup for satisfactory cooling performance. Considering the 5 options in the diagram above, which one would you pick? Heres my take:
Option 1: My top choice. Pros: Positive pressure and better aesthetics because the Noctua fans are hidden. Rear fan brings in cool outside air that can be pulled into the radiator by the top fans. In addition, it easier to clean because dust collects on the exposed surface of the radiator.
Cons: Somewhat limited exhaust because of restriction imposed by radiators. Could be an issue since I have a pair of GTX 780s dumping warm air into my case. Fans pull warm air from inside the case through the radiator.
Option 2: Pros: Better exhaust. Cons: Negative case pressure unless the speed of exhaust fans are lowered.
Option 3: Pros: Highest positive pressure out of all the options. Radiators get cool air from outside the case.
Cons: Limited exhaust. Could be an issue with my pair of GTX 780s dumping warm air into the case. Difficult to clean because dust collects on the hidden surface between the radiator and the fans.
Option 4: Similar to option 2 with the fans facing the inside of the case. Pros: Some people claim pushing air through radiators is better than pulling. This assertion is debatable. Cons: I do not like this option because the NF-F12s with their hideous color will be plain to see. Difficult to clean (see option 3)
Option 5: Similar to option 3 with fans facing the inside of case. Pros: See option 3. Cons: Aesthetics and difficult to clean.
Please suggest any other configuration not listed that will provide better performance. Thanks!
