Airflow question? how to plan airflow? Armor case
Camaroz06
Hello all,
I have a thermaltake armor case, I was wondering about airflow. I am going to add another 120mm fan to the front, one that is slightly more powerful then the one that included. Should I put it underneath the less powerful fan or above, will it even make a difference? Both will be sucking air and one will be blowing over 2 raptors.
I figure it would be best to put the "weaker" one underneath the raptors at the bottom of the case and the more powerful one in the middle blowing over the 2 raptors.
THanks
Eddie
HD's need very little airflow.
I'd imagine it would be better to have the weaker one infront of the Raptors, and the stronger one where it can blow directly towards your CPU.
Shouldn't make much of a difference though :)
