So I'm starting to think that there may be a problem with the cooling in my X-Blade case. When I feel to the left of the hard drive bay, I can hardly feel any air coming through from the fan located on the other side of it, which I'm using as my intake. Is this just stupid design on the case's part, should I be upgrading to a better fan, put the hard drive somewhere else, or what would you suggest?
There is a pic of the case posted here:
http://www.newegg.com/Product/Product.asp?Item=N82E16811105146
I'm currently running Thermaltake Thunderblade 120s for intake and exhaust with a Thunderblade 80 on the side, all at 5V because I'm a silent enthusiast. This brings me to another question, should I be having the 80 on the side, or is that causing too much turbulence and doing more damage than its worth? Figured since it was at 5V and its an 80 that it probably wouldn't hurt it TOO much...
Thanks.
Thanks.
