airbrushing
ColdFusionKid
I need some airbrushing equip. I have never been in the feild... and i am going to ask here first. I dont have alot of money... I dont need the "best" out there.
I just need some advice to get me started, and websites are welcomed
yes! i have been interested in this as well.. I did some google'ing of airbrushing stuff but never came up with too much
http://www.dixieart.com
should be a good resource, also to begin with, start with some cheapass Testors airbrush, then work your way up to an Itawa [sp]
also make sure you get a compressor and that the airbrush is dual action
edit:it is critical that you learn to properly clean and maintain that airbrush needle
How serious are you obout airbrushing. The brand Pache makes very good brushes. They have dual, and single action. Read up on them and see what stule fits you the best.
