Hi
Since I don't have time and most likely expertise (last time I build a comp. was 4 years ago) then I will relay on you guys to help me decide. Im planning to purchase a rig from AvaDirect and dont know if I should go with either:
1.
Black Thermaltake VA8003BWS Armor Full Tower, with (according to AVA description)
Front (intake) 120x120x25 mm, Blue LED Fan,
Side (Intake) 250 x 250 x 30 mm fan, 600rpm,
Rear (exhaust) 120 x 120 x25 mm blue LED fan, 1300rpm,
90 x 90 x 25mm, 1800rpm, 19dBA
Top (exhaust) 90 x 90 x 25mm, 1800rpm,
And SWIFTECH, Premium 1xCPU + 2xGPU Liquid Cooling Kit - which is most likely Swiftech H20-120 PREMIUM CPU Liquid Cooling Kits, plus 2 VGA Cooling Water-blocks
OR
2.
Stacker 830 with Monsoon II CPU Active Cooler System and 8 case fans.
DIFFERENCE IN PRICE IS ABOUT $70 IN FAVOR OF STACKER 830
Im planning to go with QX6700, 2 XFX 8800 GTX (not XXX edition since you can OC it yourself to over 630 MHz), CORSAIR 2GB XMS2 Dominator PC2-9136 DDR2 and ENERMAX Galaxy DXX Modular Gamers Edition Power Supply 1000W.
I want to do moderate OC little over 3 GHz on CPU, over 630 MHz on GPU.
Please let me know what you guys think about the set up and if maybe I should change something about other parts in the config. Please keep in mind that Im blowing my Christmas bonus on this and most likely I will not be able to enjoy the rig (I mean playing games through the entire weekend
) for more than the next 9 months ( If you know what I mean ). Please provide any kind of remark, criticism, feedback or whatever.
P.S.
Dont tell my wife
1.
OR
2.
P.S.
Dont tell my wife
