andyhoughton
- Jul 6, 2010
Hi all,
just put together my new case and would like some opinions on my fan placement.
From the description below do you think ive got my fans pushing/pulling the right way for the best airflow? The cables look a little messy from the picture but thats more the angle of the shot, theyre tucked away
I currently have two exhaust fans on the top and rear of the case. My v8 is blowing air out the back through that fan.
I have two 120mm intake fans at the front pulling air in over the HDD and into the case, I also have another 120mm intake fan on the side of the case pulling air in over my two 5850's
My 930 is OC'd at 3.9Ghz and has run through prime 95 for 5-6 hours - max temp circa 72 degrees. I'm going to push for 4Ghz tonight after work
