Haha..you noticed that too? I did a search on all of the posts he's made so far....lmfao, it's been a great waste of 20 minutes.xBuddhax said:K enough posting of which is better... do a search... it's been asked a billion times already!
ikellensbro said:As has been said, water can give you an extra 100-200MHz over good air, but you're gonna need a lot of loud fans to get close to quality water cooling. Air cooling is usually much cheaper than water cooling (any kit >175 will maybe keep you a couple degrees cooler than air...if that), but water cooling will almost always be able to cool down more and hotter components with fewer, quieter fans at lower temperatures than air.
If you live in a hot area where it's hard to the ambient air cool, water cooling's other advantage shines in that it can easily keep load temperatures just 15*C or less above the ambient (add ~10-15* for gpus, just like aftermarket gpu hsf's, cooling gpus is difficult and not as easy as cpus).
Of course, water cooling can easily look really good, with glowing dyed water easily noticeable above anyone else's computer at a lan. Their definately is a lot of "geek cred" that comes with water cooling, as it is more expansive and potentially mroe dangerous than air cooling...if you're don't run a 24 hour+ leak test.
It's really your decision about how much cooling and silence is worth it to you, I myself have become addicted to water, so you don't need to ask me if water is worth it to me![]()
well said there and ur not the only one thats addictedikellensbro said:As has been said, water can give you an extra 100-200MHz over good air, but you're gonna need a lot of loud fans to get close to quality water cooling. Air cooling is usually much cheaper than water cooling (any kit >175 will maybe keep you a couple degrees cooler than air...if that), but water cooling will almost always be able to cool down more and hotter components with fewer, quieter fans at lower temperatures than air.
