prime2515102
- Mar 3, 2003
I put a Corsair H105 on my Asus Dual-GTX 1060. My load temps dropped from 72C to a peak of 36C (24C idle).
This did nothing for overclockability. The NZXT G10 bracket is half useless (the fan half) because the VRM's are on the opposite end of the card (compared to the cards this bracket was designed for).
Would replacing the VRM heatsink with something more substantial (and preferably copper) help any or is this just the upper limit of the VRM's? If it would help, any ideas for a direct-fit copper VRM heatsink? As far as I know the size is exactly the same as with the 1080.
I know the power limit isn't my PSU. It is 750W (XFX/Seasonic) and I think I'm pulling around 350-375 peak, and probably a little less-that was measured with an overclocked AMD 7970 still installed.
Edit: CRAP! I meant to put this in the overclocking and cooling section. How do I move it?
