Regarding AIO units, such as the Corsair H70/80/90 series, which direction is best for the fan... do we draw air into the box, or extract air out of the box?
Also, if using only 1 fan, not a push pull method, would you put the fan between the case and radiator, or have the radiator flush against the case?
