Download: http://www.aimp.ru/index.php?do=download
Change log: http://www.aimp.ru/index.php?do=changelog&ver=360
Fixed: Common - CUE parser does not understand commands in lower case
Fixed: Common - player does not determine audio tracks in the CD-Extra disk if playback has been started from autorun menu
Fixed: Common - interface hangs at some time when closing the Option Dialog with active "Skins" sheet
Fixed: Audio Converter - an error occurs when trying to export to MP3 format with following settings: Stereo, VBR.
Fixed: Sound Engine - playback position calculates incorrectly for set
Fixed: Playlist - the "Default.aimppl" file is moved to the Recycle bin after each close of the application, if the "save default playlist" option is switched off
Fixed: Tag Editor - auto completion does not work for the "Genre" field
Fixed: Tag Editor - an ability of removing / applying changes to the selected tag types does not work
Fixed: Skin Engine - an error in playlist that leads to hide the element
Fixed: Skin Engine - position of main window is changed when restore it from mini-player if task bar is placed at top edge of screen
Fixed: Audio Library - playback in the audio library does not affects to the playback statistics
Fixed: Audio Library - files cannot be added to the DB via drag-n-drop operation in some cases
Fixed: Plugins - last.fm - some tracks scrobbles two or more times
Small bugs and defects were fixed
