Aida32
MrJekyll
I use a program most of you are probably familiar with called Aida32 that tells you the specifics of your system. My question is when I check the CPU type it says Intel Pentium 4 HT, 2400MHz (3x800) and in the CPUID it says Intel(R) Pentium(R) CPU 3.20GHZ so what gives?
