AI what setting do u use?
dwilson041781
i currently have my AI setting in control panel at standard always have, just wondering if i should higher it or disable?
any reviews n such please provide a link.
I just leave it at standard. I've heard that advanced can cause some IQ issues. With Oblivion i heard you had to have Catalyst AI enabled for something to work right but i forgot what it was now.
That would be for using HDR+AA in Oblivion. You can enable HDR in-game and turn on AA (up to 4x) in CCC, but for some reason it only works with AI on.
EDIT: Requires 'chuck' patch as well
Yeah thats what it is. I have the chuck patch installed and i knew i had to leave Catalyst AI enabled in order for something to work and i guess that was it.
I left it off cause it hurts performance, of course this was with a P3 650mhz and 9800 Pro videocard.
