Ahh weird message
xbreaka
right now im at 12.5x159 and my mem timings are 2 for everythin when i tried to raise the fsb by one point more it would boot and say cpu has been changed or is unworkable please check soft menu, i then lowerd it back to what i have it now and it works fine, if i tried to get better mem timgins would that be the cause or should i increase voltage?
voltage is good. if you have good memory, you should be able to run 166fsb w/ 2-2-2-6 or whatever timings. good luck though.
