ahh.. a wall?
Jason711
i have a dfi nf3 250gb w/a mobile 62w 3400.
max i can get the fsb is 230. i use a ram divider of 9/10 so its running at 194mhz.
i try to lower the multi from 11 and raise the fsb but it wont go past 230. im using dfi's latest "official" bios.. i know there are many modified ones out there, and im not quite sure which one to pick..
but im not sure if this is a board limitation or a bios limitation or perhaps even a chip limitation. anybody else run one of these things?
my vcore is like 1.54v, chipset is like 1.7v, the ram is around 3v. i have an antec 480w truepower..
oh, i can get the system to post at speeds above 230, it just will not go into windows...
right now its running at 230x11... which is 2.53ghz.. that isnt bad i dont think, but i want more. :)
