Hello,
I just got a backup drive for my PC and it wouldn't hot plug when I plugged it into eSATA. I did some research and found that you need AHCI enabled for this functionality. I checked my BIOS and AHCI was indeed disabled. From what I gather, you need to reinstall Windows in order to switch to AHCI mode. My problem is that I have an upgrade disk and can't find where I put the original XP installation disk. Is there some way to enable AHCI without reinstallation?
