Acoustique
- Nov 1, 2007
k sooo i installed winders xp & vista in IDE mode
and i want to switch them over to ahci using the reg hacks and what not, iam just wondering which order i should do this.
XP is on the primary active partion that contains the boot manager, so would i do the change on vista 1st ,then boot into xp change that, then enable ahci in the bios?
thanks
thanks
