Ahanix MCE302
Madhouse
I have the Ahanix MCE302 case... so i need a low profile agp video card... that can do component out too hook to my tv... any suggestions??? thanks in advance...
Check out the Volari V3XT. I am concidering getting that case and have read some good reveiws about the V3XT as far as TV out goes. It comes with a component output cable and is only $46 after shipping from newegg. Only thing is that it doesnt appear to come with a LP backplate so you might have to make your own. Heres the link.
http://www.newegg.com/Product/Product.asp?Item=N82E16814270008
Well so far the Volari isn't shaping up to be a good card from an HTPC stand point, lots of issues with the drivers and with component out to an HDTV. I hate to say it but there aren't alot of good low profile AGP video cards that can do component out well (not that it's any better for PCIe either but there is a LP 6600 out there) but you should check out this thread for alittle more help in figuring out what you should look for, I would suggest trying to find a good 128-bit ATI card from the 9600 series and use the component out adapter.
