AGP x800XT resolution question
xappie
Im at work, so I cant check - can someone with an x800XT confirm that this card will display 1680x1050 widescreen resolution? I just want to check before I get a new WS LCD display this afternoon...
On the original ATI factory box it says the closest resolution your wanting is 1280X1024,[1600X1200],1920X1080,etc.
Regards, Silverfox1
P.S. I just bought one of these [AIW X800XT 256M AGP] and am looking at the factory box still unwrapped, which states all the various resolutions.
I noticed the same thing on the ATI website - but I think (hope) that list is outdated, and they have added more resolutions in newer drivers... crossing fingers!
Yep - supports that resolution just fine! Picked up the monitor tonight and using at native resolution just peachy!
freakycody said:
what about the x800xl (agp)? it should run that resolution (1680x1050) correct?
I can't say for sure - but I would guess it would. I did have to install the monitor drivers for the resolution to show up in the list of options - so you might not know for sure until you have a new monitor connected.
