AGP slot dead? Help please.
PiratePowWow
I was all excited when I got my 22" HP w2207 monitor and had just started up Company of Heroes to play w/ my friend over LAN. 10 minutes into the game my monitor shuts off(goes to sleep) and the game says that I have disconnected. The fans and lights on the comp still operate and I can still hear music from the game.
I restarted and my monitor loses video signal and goes to sleep right before the screen where you're supposed to see the windows logo(and that animated fake load bar). Again, fans and lights still operate.
I swapped in another card, an ATI 9600xt, and I was able to boot to windows. But there are problems. sometimes artifacts form on the desktop and the computer freezes. I seem to be able to play Doom3: ROE without crashing(I only played for about 7 mins). But when I try to play other games such as Company of Heroes or Half-life 2 the game loads but freezes the system after less than 1 minute and the monitor loses signal. I tried another set of drivers and the problem seemed to get worse.
Other Troubleshooting steps I've taken:
Swapped power supplies with my friend's known good power supply(from his working pc)
Uninstalled the Nvidia drivers from add/remove programs
Tried switching from dvi to vga and unplugging the monitor and holding the power button to reset it.
Cleared the bios
Swapped memory sticks
Unplugged everything but the boot hard drive
SO, what do you think? The AGP slot's dead? Unless you all think it's truly pointless, I'm going to reinstall windows and reformat this afternoon.
Also, if it is the motherboard, my warranty is expired and I don't know whether to buy another Socket A motherboard (with sata and support for DDR 400) or if I should build a new computer with pci-e and sell the ram, processor, and video card from the old one. Or maybe I should get that $180 acer from circuit city and add some ram and a decent vid card. The problem with the acer is it's only got a 250watt power supply and I don't think it'll be able to handle all my hdd's and a decent video card.
Please offer some insight yall, I'm getting depressed over here.
Thanks
I would format if you can see video before the XP loading screen.
Seems like it is a good time to upgrade.
When you swapped out the nvidia card with the ati card, did you use driver cleaner pro? if not, the driver remnants could cause problems with the different cards.
Try the card in another system if you can.
Is the system overclocked?
Via chipset eh? heh... good luck.
The 9600xt was pulled from another computer where it was working fine.
I'm going to skip the driver cleaner advice and just reformat/reinstall, though I am not expecting anything from it.
The nature of the problem suggests hardware failure to me.
