AGP Skew Control?
First time I have heard of it as a BIOS setting..
But from Page 179 of the AGP spec: http://www.motherboards.org/files/techspecs/agp20.pdf
"4.3.2 Clock Skew
The maximum total system clock skew is 1 ns for all data transfer modes. This 1 ns includes skew and jitter which originates on the motherboard, add-in card, and clock synthesizer. Clock skew must be evaluated not only at a single threshold voltage, but at all points on the clock edge that fall in the switching range defined in Table 4-10 and Figure 4-25.35 This is measured between the pins of the two A.G.P. components (not at the connector). The total skew and jitter is allocated so that 0.1 ns originates from the add-in card routing, and 0.9 ns originates from the motherboard routing and clock synthesizer. The motherboard designer shall determine how the 0.9 ns is allocated between the board and the synthesizer. To correctly evaluate clock skew, the system designer must take into account clock distribution on the add-in board as specified in Section 4.4.5.1. "
It looks like a way to tell the Motherboard/chipset to adjust for up to a 1ns clock delay between the video card and the AGP bus. I would say disable it, unless you have video problems.
==>Lazn
