AGP Question for 9800Pro
C|ip$3
I have a 9800Pro, and I noticed under the SMARTGART tab in advanced options on the card. I'm currently running my AGP Speed as off. I set it to 8x and restart, then it keeps resetting to it back to off. I have the MSI KT4V board, is there are option in the bios where I change/set my AGP speed? The board does support 8x too. I'm guessing this problem is also effecting the performance of the card, right?
i had the same problem and i set it in the BIOS and inside of windows also..fixed it for me..fastwrites and 8x agp are now enabled :D hopefully there is an option in your BIOS so you can set this to the correct setting
