AGP Pro 150 Mobo
Rockjay420
Help, i accidentally bought a Pro 150 Card, worth over 300, but i cant return it
Ive been loooking all over the internet with out sucess, trying to find a voard to support it, that wasnt 10 years old.
several of Asus's high-end agp mobos had AGP pro slots. For socket A, I'd recommend the A7N8X Deluxe. For socket 478 I'd recommend the P4C800 Deluxe.
how about socket 939? and what kind of graphx quality can i expect from a pro 150 card? lower then a pcie at the same clock and memory and pipes?
I have a Supermicro P4SCT-II that has AGP Pro and it is an amazing board. I just wish I didnt loose one of my PCI-X slots to the massive coolers on most AGP Pro cards.
AGP Pro is a pretty old specification. Is that a workstation card (FireGL, Wildcat or Quadro model)? Those were faster (or much faster) than gaming cards at the time for certain apps (CAD, modeling, etc), but i think virtually all have fallen behind mainstream gaming cards now for the same apps. But they could still support features (or drivers) that gaming cards don't in those apps.
THG had a PCI-E scaling (x1-x16) benchmark back in 2004 that showed CAD and modeling apps can use more than x8 PCI-E speed (roughly equal to AGP8X bandwidth in one direction... AGP Pro is either 2x/4x or 4x/8x). It depends on what applications you're using, but in general a PCI-E card should do better than an AGP card in professional apps.
