AGP or PCI-E
Decay
as of right now which kind of interface is faster/more reliable just the overall better buy, AGP 4X/8X or PCI Express x16?
PCI-e is the way to go. You may not even be able to get any new cards for AGP if 7800 sets the trend.
PCI-Express hands down is the way to go these days. AGP is slowly getting phased out. If you are getting a new rig or motherboard even, get it with PCI-Express.
right now there is little if any difference in performance between the AGP and pci-express versions of the same card, but the pci-express version tends to be slightly cheaper. However, that is offset by the need for a pci-express mobo, of course.
If you're starting a new build, go pci-express.
You want a Socket 939 64bit Mobo... That has PCI-E SLi :p
Thats what you want to stay up with the lastest....ASUS A8N-SLI Deluxe should do the trick ;)
Go for the Asus A8N-SLi Premium. That is the board to have in my opinion.
My question is why go PCI-e when nothing requires anything close to the power that PCI-e gives.. All you doing there is wasting your money.
well if you want a card faster then a 6800 you need it
plus there's SLI if you want it. AGP can't use sli even if you tried to make a mobo for it.
well as of now, Im not gonna get into SLI, Im gonna wait a little longer till I upgrade to that, I dont think that right now its worth paying extra for SLI when you can get the almost same performance with a singe VGA card
