Mercenarie
- Jun 27, 2006
im looking to buy a agp gfx card that will run games like bf2,bf2142.doom3,farcry,cod,moh and etc on high settings. my budget is 140. does anyone know if all agp mobos are 4x/8x?
I have the same one.. It can play just about any game you throw at it right now on high with the exception of Oblivion or GRAW, and no AA. I can play fear, doom3, q4, etc, all on max settings no AA (1280x1024), and it gets around 60fps easily with no lag even in high action areas. You should be happy with it. You can use Riva Tuner and unlock it to 12/5, and it overclocks stable to 450/1250 pretty easily.Mercenarie said:i just purchased is their any reviews for this? what games can it run on high?
http://www.newegg.com/Product/Product.asp?Item=N82E16814150157
AMD Athlon XP 2200 @ 1.80ghz
512mb RAM - upgrading to 1.5
60 GB Hardrive @ 5200rpm - upgrading to 200 gb
Bastek said:I also got this xfx x6800xt agp, and cannot be unlocked to 12/5. It goes back to 8/4 active.
it's made from the pcie chip with bridge. Anybody got it right?
Not to rain on your parade but hours ago you asked what card to get and then you come back saying you already bought this card when most people were steering you towards other cards. If its already shipped you might as well make the best of it. However, in hindsight you would have been quite a bit better off with that x850proMercenarie said:i just purchased is their any reviews for this? what games can it run on high?
Def means default.. wrong? I thought "cur" means current running, and "tgt" was your target settings.Bastek said:Show me the customize screen, and you''ll see you are still active 8/4 on top. No go.
GonzoP said:Don't wanna thread jack this but did you even consider the 7600GT before you got the 7800GS? I know its often OOS but our two cards perform about on par with each other only I paid like $17X for mine
