Hello all, maybe your advice can help me through my AGP nightmare.
Just bought a new HIS ICEQ x1950.
Installed the distro from the HIS website. Set up froze during WDM install, then gave me an remote procedure call error mesage after I forced it to end. Then the distro continued to load the rest of the drivers just fine and said setup completed successfully. Opened cataylyst and there was no video preview. So...
I tried the Omega Drivers. They did not help anything. So...
I used driver cleaner, then force installed the drivers only. HL2 worked beautifully all settings maxed. So I decided I wanted to reformat anyways to smooth out everything including some viruses and what not and I wanted the driver install to run completely.
This time, the same thing happened. But HL2 doesn't make it to the main menu without crashing. So I decided to use the newest drivers from ATI's website, to see if maybe the install would run entirely (including the WDM)...Same thing happened. It got to the WDM and froze then continued to install everything else. And this time the catalyst previews worked..But...HL2 still doesn't work.
So I repeated my last steps of driver cleaner and now in the process (at work so have to wait) to reinstall the driver only from teh HIS website.
______________________________ ______________________________ _____________
ANY SUGESSTIONS? Is this normal? Is it fine to use just the basic drivers without all the extras? If so what do I nEED? I just want to play games, by card is beefy, I don't need to overclock or anything. But it would be nice to have catalyst.
I use SK8V, Fx51, 520 psu, 2 gb memory (just installed 2 new 512 sticks with the video card)
