AGP 4x - best card?
MrGuvernment
Hey all
Not sure on this one, want to grab something to game a little on with an older AGP 4x system, p4 b 2.4
now i know, or think when they went to agp 8x there was a power revision? so many neweer agp 8x cards wont work on an much older (to be specific, 4 year old) AGP slot that is ONLY 4x AGP. one has a 1.5v and the other 3v ?
wondering if anyone knew what was the fastes / compatible for 4x AGP.
i am guessing a 9800 XT or lower? as the x800 line, they were the new AGP standard no ?
if your agp port is 4x port...
then lol you can use pretty much any AGP card in the market now... i believe even x1950xt agp... but ofcause.. your p4 2.4 will bottle neck it back>>>
as long as it is not agp 1-2x port which only do 3.3v
then all those new card in the market should work
if your psu is up to snuff (450watt, 30amp on 12v rail recommendation) you should be able to run the x1950pro with a negligible impact versus having agp 8x.
awsome, thanks for the info, didnt hink 4x was still well, "okay" this wont be any hardcore gaming,mainly some CS:S here adn there and maybe something else, just something that wont drop to 10FPS on dust2 like the crap fx5500 i have right now :) at 1024x with everything on low.
I whipped this up in all of 12 seconds in paint. You should watch out for this sort of thing. I have the 2x/4x on an old board I wanted to make a spare CS 1.6 and Guild Wars box out of. The 6600GT I ordered for it showed 2 notches in the pic on newegg(which means it's universal to the types of agp slots) but the one i rec'd from them only had one notch in the 4x/8x format. It's kind of a headache waiting for a card to come, having spent $100, just to find that you have to mail it back for $8 shipping.
Hope it helps ;)
Appreciated, will check that, i am sure it has the 4x/8x notch but will have to check, as since i am in costa rica, sending the card back, for me is cheaper to buy a new one :(
