Freezebyte
- Sep 21, 2008
Hey all, I''ve finished my specs for my newest system build which will consist of a Core 2 E8500 on a ASUS P5E-VM HDMI board with 2gigx2 G.Skill DDR2 800. This will give me the ability to hopefully overclocking to at least 400mhz FSB and i'll pretty much call it a day for OC as it seems to be pretty easy with these Intel chips and I haven't OC'ed since my P4 days.
I've heard some stating that the stock Intel HSF will handle the job, yet others say it will not. This setup will be housed in a Silverstone SG01-F case, so I don't have alot of room, hence my aftermarket HSF options are limited. My PSU is a Antec NeoHE 500w which DOES not have a bottom fan, just an outside 80mm fan, so the Silverstone NT06 series won't work.
After much research, iv'e narrowed it down to these. I'd like to know what everyones thoughts and suggestions are to replace the Intel stock HSF with something better for a light OC so I can hit 3.8ghz hopefully.
ZALMAN CNPS 8000
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118005
Zalman CNPS7000B-Cu
http://www.frozencpu.com/products/1482/cpu-zal-13/Zalman_CNPS7000B-Cu_Intel_Socket_478_775_AMD_Socket_462_754_939_940.html?tl=g40c14s52
Thermaltake Blue Orb II
http://www.frozencpu.com/products/1472/cpu-tta-29/Thermaltake_Blue_Orb_II_CPU_Heatsink_w_Blue_LED_Pentium_4_LGA775_AMD_754939940AM2_CL-P0257.html?tl=g40c14s52
Arctic Cooling Freezer 7 LP Low Profile
http://www.frozencpu.com/products/8090/cpu-arc-20/Arctic_Cooling_Freezer_7_LP_Low_Profile_Media_Center_CPU_Cooler_Socket_775_-_ACFZ7LP.html?tl=g40c14s52
ZALMAN CNPS7000B-AlCu
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118118
ZALMAN CNPS 8000
Zalman CNPS7000B-Cu
