After shipping my box, won't boot... ->>
escapist13
I shipped my computer to myself in what I thought was a very well padded and sturdy box. When it got here, the box looked fine and so did my comp. However, it won't load XP. It'll post, I can go into setup, but as soon as it tries to load the OS from my HD, it just says "Press a key to reboot." And that's where I get screwed.
Does it sound like the HD is damaged? I remember there being some program I can put on a floppy to check the HD. Anyone know what I'm talking about? What do you suggest I try next?
Please help. That HD is my life...
What I would do escapist13 is check the IDE cables first, then I would check my hard drive with the program that is shipped with the hard drive (lifeguard tools-western digital datalife-seagate if I'm right). then I would try to install windows XP on the computer just to see if it will install. If it does (do this before install windows XP or step above) run recover console from windows XP disk. then procede to check it out.
If your serious, thats kinda pathetic.
What could possibly be so important that it is your life? I can see maybe if you do your bills / taxes online and had everything on there, but other than that, just reformat dude. If you have a good internet connection you can get your stuff back in a few days.
I would just plug the HD into another computer... then see if it is okay, back it up, and reinstall windows.
