Well, I've got to ask. Do you really need sata3?
Good point, and they are cheap on ebay. I got one for $75 or so and flashed with IT firmware.
IBM M1015
thanks, i noticed that and found some for $15 awesome stuff!
I don't need 32 cores in this build eitherBut its the latest tech, and the SSD drives i'm using also support it. I don't see any reason to cut my IO in half just because of a controller.
