Hey guys, I'm currently looking for a good mid-tower case to suit my next build.
To keep this a little simple since I dont know the complete specs of my coming build, I'll be using a full atx motherboard, planning on getting a i5 3570k, quite possibly a thermalright true spirit 120. Along with that, 1-3 hard drives, no water cooling, hx750 psu, and I'll be using my current 5850 for the time being, but will very likely get something better at some point (though not likely a dual gpu, not too concerned about will I be able to fit 12"?)
Budget is about $100, give or take. Current interests are the corsair 400R and the fractal design define R3. I had been looking at the HAF 922 but have decided against it after looking at the 400R seeing as it offers little to nothing better that I could find (and looks considerably worse). As it stands now, I'm leaning towards the 400R. It will likely have superior cooling based on all that I have read over the R3, with the potential downside of allowing more dust in, and being louder.
Thanks guys in advanced for the help.
edit: I'm not sure what happened to the topic. I typed something else in, dont remember what exactly, perhaps I missed something.
