Aeron chair
iTravis
I'm in the market for a new chair and I've heard great things about the Aeron as I know some of you are absolutely in love with it. My question is that is it really worth it to buy it brand new or get it used/refurbished to save a few hundreds? I've seen some listings on my local CL selling for about $500 for the fully loaded version and they said it comes with 90-day warranty.Also, is there a significant different between the basic and fully loaded version?
If it's ok to go with a used one, where else can I find it for a decent price without breaking the bank? (I live in SoCal). Are there other alternatives to this chair?
Please give me feedback on this, thanks in advanced. :)
I received a used Steelcase chair for a graduation gift and I must say it's one of, if not the, most comfortable chair I've sat in. I've had it for at least a few years now and have had no problems with it. By looking at their website I'm quite certain it is the Amia model.
My dad has an Aeron and I can indeed attest to the fact that these expensive chairs are definitely worth it.
Quoting this sentence because my dad happens to have one as well and my impression is the same :D
At that price, it better be comfortable. :eek:
We have the Aeron at work and I don't like. The springy mesh thing is comfortable, but the rigid edges it attaches to cut in on my legs. So it's super comfy, other than this strip of metal digging into the back of my thighs.
I bought a Human Scale Freedom for home and it's comfy. I was originally looking at Human Scale for their sit/stand desk, but ended up getting a motorized one from another company. In retrospect, I'm glad I didn't get the human scale desk. With motorized, I can come home and set my laptops on the desk and not have to mess with the tension setting.
I don't know anyone that intentionally puts pressure on their legs while sitting. You may want to consider adjusting the height so your feet are on the floor rather than your legs dangling off.
Thanks for the feedback guys, I think I might go to a retail store to give it a try first. Also, is it ok to buy it used or refurbished?
Well, I already gave you my experience with a similar used chair.
If you're not set on the idea of spending $500 on a chair, stop by Staples and have a sit in their "Hyken" mesh chair.
I picked one up about a month ago now for $80 (sale + $50 coupon) and it's very comfortable. The shape is well proportioned, full mesh seat/back/headrest, adjustable lumbar support. The Hyken also has a soft pad along the front edge under the mesh for support so you don't end up with a pressure line across your thighs.
A new Aeron comes with a 12 year warranty. I'm not sure about a used one. I would check on that.
I got the basic version new on Amazon for $594.00.
Normally they are more expensive, but they go on sale twice a year. I'm don't remember when though.
The biggest difference between the fully loaded and the basic version is that the fully loaded has adjustable arms and the basic one has fixed arms. You can adjust them, but you have to take the chair half-way apart and adjust the screws. It really isn't that big of a deal because once you get the right spot you shouldn't need to readjust them.
The chair comes with a guide on how you should sit and adjust it for perfect ergonomics, it probably wouldn't if it was used, but I'm sure you can find it online.
Another thing to consider is which size you want. There is A (small), B (medium), and C (large).
If you're 6' or taller you want a C, I'm not sure how the other sizes match up.
I highly recommend getting an Aeron. I've had one for about 3 years. I was having some back pain when I sat at my desk for a long time, but never after switching to an Aeron.
I don't mind spending $500 on a chair, in fact I already set that amount of money when thinking of getting another chair to replace my current crappy one. But as you probably know, I just want more inputs before spending that much money on a chair, the more ideas the better so I can get to decide myself. And thank you for the suggestion, I'll give it a try when I go to Staples.
Thanks a bunch, this is what I need from a user. Since I'm in no rush of getting one I guess I can take my time and wait for a good deal, or as I just asked earlier, I might consider getting a used one if it's worth it. I'm just not sure whether I should pay more for the brand new one with the warranty vs saving some money with a used one that might or might not last that long, not to mention the problems I might run into with a used one, kind of a dilemma as you know it.
I read a lot of reviews and found out some people are not happy with the basic version due to the lack of adjustments so I think it would be best for me to go to a retail store and try it out to make up my mind. If what I need is a fully loaded version then I might have to reconsider or take more time before dropping a grand for a brand new one. Also for the size, according to their chart, my 6' 185lbs frame would fit on a B size but there are some around my height said the C is uncomfortable for them. :confused:
