Aerocool Masstige
Casper312
Sorry if i misspelled the case name. I have owned this case for about a year and a half, and it still makes me wonder.
I was wondering if anyone still has this case and mind sharing some case wiring secrets, I have pretty much just hidden all the cables between the Psu and Dvd Drive (All the way at the bottom). I had some ideas of moving the dvd drive up one level and just hide the cables under there.
Another question i had was hard drive placement, I currently have my harddrive in a front drive bay cause my ide harddrive wont fit in there, meaning it hits the side panel and makes it hard to close. i also have no idea what clips to use to make it fit in there, Well its not that much of a problem, seeing as how it prob gets more air flow from the front, but then again the side fans might have a purpose then just blowing air into my thermaltake 120 ;p.
Last question is, pretty much if thermaltake still has the bracket to convert 3 drive bays into a 120mm fan bracket. If so if you can link please or if you might have one around from an having this case before, Give me a pm and lets work something out (i will end it at that since this aint a fs forum).
Thanks for any tips/helpful stuff that might be posted, I tried finding the aerocool gallery thread but i cant seem to find it.
