Etherton
Will Bang for Poof
- Aug 7, 2006
Just finished (for the most part) my build with this case. Not a lot of room in here and had to make some modifications and remove anything I wasn't going to use. I plan on shortening the cables (brother can make them to length for me) and adding water cooling to that Kingpin, somehow. I had to put the GPU in the outer PCI-e slot - does that matter as far as performance goes? My Corsair H100i has the noisy pump issues. Planning on calling Corsair Monday about it. I bought the 4770k and done a delid - temps rocking 30, 30, 28 & 30. Planning on seeing where this chip lands for overclocking.
System:
Using the following existing parts:
Photos:
System:
Intel Core i7-4770K (picking up at Microcenter)
Corsair H100i 77.0 CFM Liquid CPU Cooler
Asus MAXIMUS VI GENE Micro ATX LGA1150 Motherboard
EVGA GeForce GTX 780 Ti Classified K|NGP|N
beQuiet Dark Power Pro 10 850W
LG Bluray burner
16gb - G.SKILL Ripjaws Series 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Intel 525 Series Lincoln Crest mSATA 240GB SATA III
1 - 1tb WD Black HDD
Photos:
