aero.x
invalid_
Project: aero.x
aka: inspiration culmination
For a while now I have been planning a new mod and recently got it started. I named this project aero.x as it will yet again be a air cooled machine. I started in photoshop making a quick logo.
The logo will be placed in multiple areas as appliques.
The basis of this mod is taking a shuttle system and placing it into a mid tower case. I chose the Coolermaster ATC-110B. I wanted the motherboard to be covered and to have the hard drive below it. The shuttles size makes this very easy.
Here are the plans for the inside to understand where I am going.
Motherboard cover:
Full inside view:
The top of the inside will have a black acrylic cover with a second piece below it that is clear with blue leds lighting it.
The first thing I did on the project was take the original case and cut out the areas I did not want. I cut out the hard drive bay area as I would not be using it. I only did the one side thus far. Ran out of cutting discs.
Then I bought some acrylic and metal from some local shops. While there I got this huge piece of perforated aluminum.
I used black acrylic for what would be the motherboard cover. I then heated and bent it into the shape I wanted
Next I drilled two holes for vents
Holding it up to what will be behind it
Next I need to cut out more vent areas and make the spot for the video card as it will protrude through it.
CONTINUED BELOW:
With the metal, I cut out new areas for the back and the inside. The inside will be the base for the components below the cover.
Test Fitting the shuttle and pieces:
Next on my list is getting the inside mounted and cleaned up. Then I can get the chasis painted black. The inside will all be black with some aluminum areas and blue lighting.
Lots and lots more to do but it has begun. :)
Instead of trying to make a new mount for the motherboard and such I decided to just implement the existing shuttle chasis.
I mounted an aluminum sheet cut to size in the back of the main case
Then I measured and fit the shuttle chasis into place which I gutted to only the bottom base and the back.
Once I had it where I wanted it I mounted it with a few screws
Finally I was able to measure and cut the new backplate to cover the excess area. I also included a hole for an 80mm outtake fan in the bottom back.
Held up to the area before filing and cleaning
Now I just need to grab some cutting discs and remove the other side of the hard drive cage and the chasis will be ready for some filing, sanding, and finally painting. I should be able to move to the window cutting this week if I can find some time.
I was unhappy with the original backplate so today I made a new one fixing the issues I had.
First I cut out the area that will be open with a jigsaw
Next on the sides I wanted small tabs where the thumbscrews will attach it to the back of the chasis
Next I drilled holes in the tabs and attached the new backplate to the chasis
For a visual look I put the mobo cover in and an old speaker that I am using for a wire culmination house.
Wire House
It was at this time that I found my first issue. The area for the AGP video card has fallen into the curved area of the plastic. This area has to be cut out so I might have to make some adjustments.
From behind
The second slot is for the AGP. Decisions. :)
I am off to grab some cutting discs to FINALLY remove the other side of the HD cage. Then I can file, sand and prep for painting the chasis.
BTW> Anyone know where I can get some green UV plexi? PerformancePCs has been out for a while and cannot find another supplier in the US.
I started on the top acrylic cover. This is black acrylic and later when I buy some UV green it will go below this with the edges glowing.
I cannot wait to get ahold of the green UV acrylic as right now its all feeling very black. I need that to set things apart.
For a long time I hated uv acrylic. I just could not get a good vibe from it. Orac3 of course was an exception. Over time though I fell in love with a few projects that really inspired me in my current work. The one that got me turned around on green uv acrylic is Franklins AlumaxX . Its all because of him and his project that I even included this at all. I thought long and hard because I did not want it to be like everyone elses case. But I finally made myself realize that if I like it, theres no reason not to do it just to not be like someone else.
So later on tonight will start the UV acrylic part of this log.
I ordered the acrylic from mcmasters and it got here the very next day! Nothing but A+ from me. I didn't do much yet as I am about to walk out the door to get some things but here is a small glimpse of where we are going. :) Keep in mind the acrylic has not been cleaned nor the edges filed/sanded.
Also before this I painted the chasis and the pieces that will go inside black. Putting it all together later tonight as well.
( You can also notice I finally finished removing the hard drive rack on the case )
See you later with some movement/updates.
I finished the two vent areas on the mobo cover. I just need to attach them now. Ignore the misalignment they are only taped from behind right now.
Going to Sand the edges and finish the mobo cover tomorrow.
While at Home Depot I also found this cool shower head.
I was looking for a while for a good housing for all the wiring for leds and such. This will be the house with a hose going to it and then several small chrome attachments connecting into it. I took it apart pretty quickly.
And here it is stripped sitting on the acrylic it will be on top of in the final project.
The final thing I did real quick tonight was put back together the cases pieces that I took apart to paint. Here is the chasis now back together and painted. A couple spots are still drying in the pic so you might see what looks like smudges. Just not dry there. Sorry for the darker pictures, I was losing light.
Thanks for the comments all.
Update
Today I cut out the top window and fitted the new material for it. Because the case I was using was used and had previous cuts in the top I had to cut this area, but I did not want a top window. I am just not a big fan of them. So I instead decided to use black acrylic and some mesh. The mesh will be painted black, or have black acrylic below it in the final version. Right now the pieces are just test fitted and not fully installed
Area drawn
Cut Out
Put on the chasis for a quick look (Sorry this one is blurry)
Molding installed.
I also am installing molding on the mobo cover holes
Black acrylic in place on the back hole
Mirror finish of acrylic is so nice
Cutting the mesh
Mesh placed
Moving on next to the window on the side door and the hinges. Possibly later I might get the balls to finally cut out the area for the agp card on the mobo cover.
You've got some amazing design skills. The top windows look absolutely incredible. Lovin the dark plexi, can't wait for the next update!
Thanks guys! I hope to have at least one more update before the end of the day. :)
I finished the vents on the mobo cover tonight. Now the next thing with the project will be to finish the hole thing. I have been putting it off, but I need to get to it soon.
Then I cut the green uv area to cover the top. I made a black one earlier, and that will go on top of this. The edges only should be showing.
I then put the top back on the case to get a feel for it. I took the tape off of one side of the acrylic, but the back side is still covered. The mesh on the of the case still has to be painted black. Its silver in this picture.
Thats it for tonight. Time to head out and do a bit of partying. Tomorrow I have baseball practice during the day, so hopefully later in the day I can get back to work!
Very nice mod so far. I love the abstract look you're giving this mod. Too many people try to make a mod with a theme instead of comming up with something truely original.
Thanks Sheldron
I need some opinions. Should I leave the top mesh area silver, or should I paint it black to match the acrylic area?
1.
2.
I am really torn on it. I like both.
Today I also quickly made the cut for the acrylic that will be where all the wires connect into.
And attached to the cover
invalid_ said:
Thanks Sheldron
How about painting the mesh gloss black, and instead of black plexi under it, you use some of that sexy green?
This is a definite possibility. I will try this later. Thanks for the idea!
id like to see how the green under black looks but i think it might however be TOO much, that black mesh definitely looks outstanding though.
Part of me agrees. Originally I wanted the exterior view to be black/silver only. And then the inside only have aspects of glowing green. The top will definitely be an experiment at this point. But who knows.
Wow, very nice work. Where did you get the black grommet type stuff that you lined the mesh with? I've been looking for something like that for a while now...
I definetly want to see this finished.
Thats U moulding, you can buy it from any modding store, and probably elsewhere too. There's also H moulding that allows for the inner and outer surface to be flush with eachother.
I buy my molding at auto stores. Its door edge molding. Works great and is very cheap.
heres a vote to make the mesh black, i just think it looks a lot better in th picture black!
Chris
I like the black over the silver, and i agree with the green plexy underneath comment.
Gotta watch this thread...
WoW omg this is a nice clean job you are doing, I like the green acrylic that you are using.
Thanks guys. Really appreciate the feedback. The black is definitely going to happen tomorrow.
I already started planning the front which I will start on soon as well.
