http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1030337&Sku=A644-1704
Seems too good to be true.
Are any units easy to strip out?Furystrike said:Anyone know how well this thing strips out? If you dont have to extend any cables....This sounds like a winner for DIY projectors.
SJetski71 said:Are any units easy to strip out?
Nice, thanx for the heads up too! If what you're saying is correct then big screen projection is in my future. Boy that sounds funny.Furystrike said:Definately, I know of a few BenQ's for certain. You can pretty much dismantle any moniter in an hour, the only problem lies in the angle/length of the flex cables. Check out the www.diyaudio.com video section if you're interested in cheap big screen projection! I personally have a 120" screen set up in the dorm with a nice pull down screen (aka window blind) All of it only cost around $250 300! Gotta work on my bulb life though...Costs me about $0.10an hour to run it right now
^^^^ PM sentFurystrike said:N/p bro, if you have any questions about DIY projection, go ahead and ask
