Advise PSU
Gn0m4
Silverstone FT-03
I5 3570
mATX Sniper M3
16 Gb
SSD & 2x HDD
Sli GTX660
What do you recomend for these components?
I would like modular and not too long cables.
Around 600w would be more than enough. Check out Silverstone's gold series.
any good psu you could find will power that, it will probably use under 450W with the hardest load you could imagine.
PS: just get a gtx 680 or 670 for the love of pete. does the regular 660 even do sli? anyway, skip it, get one better card!
Yes, non-Ti 660 should do SLI. But I do agree, forget running two lower end cards in SLI and just get one higher end card. Two GTX 660 runs around $460. $20 more can get a GTX 680, and you can save that much on the PSU since one 680 uses less power than two 660.
