advise on my first loop
Beefcake
Hey guys im building my first loop i have a thermochill p120.3 rad xspc x20 750 pump/rs using 7/16 tubing i know this will b good enough to run a gpu and cpu but i was also wondering if i can attach a second res such as a FrozenQ 250mm Liquid Fusion Reservoirs in this loop as well cuz i think they are awsome im worried the pump is just not going to cut it for this build and i would like some advise on the matter all advice would be appreciated thanks guys
If anyone is interested in seeing what it looks like so far here are some pics of my setup so far was pressure testing the rad to make sure it had no cracks
Not sure if im not getting any help because i did not give enough information the kit started out as a xspc rasa rs240 i changed from the xspc 240 rad to a thermochill p120.3 radiator seen in pic above i wanted to install another reservoir that i could see through the window i'm definitely installing a cpu and gpu water block i'm a bit worried that that the pump is not going to b good enough to do another reservoir seeing how large the radiator is to start with ill b using an 8350 as a chip and i'm waiting till the new generation of gpus from amd are released in Q4 to there flagship and put it on a water block i hope this can help with any of the information you guys needed to give me help thanks
