*Advice
My current specs:
i7 2700k @ stock (no oc plans)
MSI GTX 760 (no oc plans)
mITX Msi b75ia e33
8 gb crucial ddr3 1600 mhz (no oc plans)
1 x ssd & hdd
Waiting for the Ncase M1 to arrive and the Silverstone sfx 600w to be available.
Until then i'm using a +5 years old Seasonic S12II 500w Atx with 37A.
If i may some questions:
1. My video card has 2x 8 pins (surprisingly).
Only had 6 and 6+2 from the psu
Used an adaptor 6 pini to 6+2.
Any problemes for this setup with the adaptor?
2.Is the age of the psu a problem for the i7 + 760?
I always cleaned it, don't think i used it at 100% load (e8400+8800gt then used a gtx 470)
Now in gaming like Watch Dogs, no wierd noises from it or the fan, not even heat.
I mean asking if it will do the job safely for how much time.
3.Is the Seasonic S12G 750W a good and quiet psu?
If the ss sfx 600w is bad for any reason just to have a back up - for the Ncase i need a non modular atx 140 mm psu)
Thank you.
My current specs:
mITX Msi b75ia e33
1 x ssd & hdd
Thank you.
