Well I'm setting up my loop and I've gotta say, this isn't as easy as it looks
That being said, luckily I'm working with Tygon, so I get as much bend as possible. Some of the things I'm trying to pull off are a bit tight, and I'm not sure exactly when the bend is considered a kink, since I know they should be avoided like the plague. On to the pictures...
In these two shots, I'm concerned about the line that goes from CPU->T-Line->Rad. It is a bit tight there, but from the look of the pictures it doesnt seem to be kinking, correct? I don't know if it's a slight thing that can kill your performance, or it's straight up obvious. Any suggestions on this run here? It was a bit difficult since that's where I've gotta place my T-Line, considered the bottom of loop but I don't want a long tube running verticaly up the case.
Here I'm focusing on the tube going from the T-Line, between the radiator. You can get a better idea of what I'm trying to achieve in the first picture, the tube is supposed to run between the heatercore's barbs, and it goes straight up to a fillport on top. The second picture gives you a better idea of the bend in my oppinion. This seems to be bending more than the others, would it be considered a kink that can not stay? Since it's the fillport, and water does not normally flow through it, is kinking ok provided the water will still work its way down there initally?
Finally a picture between the CPU and the GPU. Everything isn't connected, but it's close enough for a general idea I think, does the bend look ok near the videocard? *Sidenote* Check out the reflection on that maze4
Any help would be appreciated, I'm not sure what I'm looking for and what is ok and what is not.
Thanks
Thanks
