grandmaster
- Apr 19, 2006
Hi,
I'm looking to build a mITX system with either socket 775 quad core or one of the new Clarkdale set-ups.
I'm looking for the smallest possible set-up, factoring in that I will be using one or two SSDs (no bulky desktop drives required). An optical drive is not necessary.
The only issue I can foresee here, aside from heat dissipation, is that I need to get a half-height PCIe expansion board in there too.
Can any one suggest a potential case/cooling/power solution?
