Jun 25, 2019 #1 A amundsen n00b Joined Aug 1, 2018 Messages 24 Hello, Which way do you recommend to achieve this overclock? Should I use the factory Asus BIOS utility (accessed with F12 at startup) or would you rather recommend an other way, another program? Thank you in advance.
Jun 25, 2019 #2 pendragon1 Extremely [H] Joined Oct 7, 2000 Messages 52,226 yes to do it properly you oc in bios. you can try an oc tool like asus' see how it goes and then copy the stings into bios.
