Advice/suggestions: $700-1000 Intel build
warmchords
EDIT: Just noticed the sticky.
Multi-tasking in CS4 (I use Photoshop and Illustrator almost daily) and occasional gaming.
My ideal budget is $600-750 pre-tax and shipping costs, without monitor.
3) Where do you live?
Murfreesboro, TN
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything listed below.
All new components.
6) Will you be overclocking?
Yes, at least CPU.
7) What size monitor do you have or plan to have?
19-22" at 1680x1050 preferably.
Late December/Early January
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I don't plan on using Crossfire/SLI or RAID. Firewire would be nice, but I plan to skimp on this motherboard.
Hey all,
I'm getting ready to start ordering parts for a rig that I'll be assembling in early January. It's a general purpose build that I expect to multi-task Adobe CS4 well and also handle the occasional game - I don't have time for much gaming anymore, but I am looking forward to Fallout 3. This is what I've got lined up so far:
Mobo: GIGABYTE GA-EP45-UD3R
CPU: Q6600
GPU: ASUS EAH4850 TOP/HTDI/512M Radeon HD 4850
Memory: CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
HDD: WD6400AAKS 640GB
PSU: CORSAIR CMPSU-650TX 650W
Case: Cooler Master Centurion 590
CPU Heatsink: XIGMATEK HDT-S1283
Optical drive: SAMSUNG Black 22X DVD+R
Monitor: Acer X193W+BD Black 19" 5ms
Total: $930~ if I were to order from Newegg today. Several MIRs apply, but by the time I figure in ridiculous TN tax they would probably balance each other out.
I've already exceeded my original limit, I really wanted to keep this build closer to $800 originally. If anyone has suggestions for alternative components I'd love to hear them, or advice for when to order to get ideal pricing (ie. should I wait until after Christmas? January? I can't remember how much Newegg's prices usually change after the holiday season.) Any input is appreciated. Thanks!
Hmm.. That PSU is a bit more than you'll be needing, you can save a few bucks if you go down to a 500w. The video card is also a bit of overkill if you only plan on playing games every now and then, but for the price it's a worthy investment. If you can find something cheaper but still with the same power (I've seen 4850's go for 110 including shipped on [H]) then I'd go with that.
Besides that, everything looks good (quality/performance-wise). Ordering bits and pieces from [H] and using newegg combo deals could probably save you 100+. Go browse the FS/FT section ;)
GL with the new build!
Let's go with this man. I downgraded your GPU and PSU but, gaming is not your main priority and the 400W Corsair PSU is enough for this system.
Case - COOLER MASTER Centurion 590 for $50
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119152
PSU - Corsair 400W($10 MIR) for $60 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008
Cpu/Mobo (Combo Deal) - Intel Core 2 Quad Q6600 + Gigabyte GA-EP45-UD3R($15 MIR) both for $285
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.147899
Ram - 4gig G. Skills DDR2 800 for $40 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
Video Card - SAPPHIRE 100265L Radeon HD 4830 512MB($10 MIR) for $115
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102803
HDD - WD 6400AAKS 640gig for $75 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
Optical - SAMSUNG Black 22X Sata DVD burner for $25 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151171
Heatsink - XIGMATEK HDT-S1283 120mm Rifle for $37($10 MIR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
Retention Bracket - XIGMATEK ACK-I7751 for $8.50 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233019
Monitor - Acer X193W+BD Black 19" for $140 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009127
Total: $835
Or... you can go with other Quad setup and save even more money.
Case/Psu - Antec NSK4480 Black w/ Antec Earthwatts 380W for $75 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129031
Cpu/Mobo (Combo Deal) - Intel Core 2 Quad Q8200 + Gigabyte GA-EP45-DS3L($15 MIR) both for $270
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.147893
Heatsink - XIGMATEK HDT-SD964 92mm Rifle($10 MR) for $28
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233014
Retention Bracket - XIGMATEK ACK-I7753 for $15 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233020
Total: $783.00
(Bumping this to reflect some tweaks made and what I have left to order)
I just ordered the following early to avoid paying 9.5% TN sales tax, because this stuff will fit in a bag on the plane before I go back:
CPU: Q6600
GPU: Sapphire HD 4830
Memory: G.SKILL 2x2gb DDR 800
HDD: WD 640gb Caviar Black 32MB cache
This leaves me about a week to pull the trigger on the following:
Case + PSU: Antec Sonata III w/Earthwatts 500W - $100 free ship
Mobo: - Gigabyte UD3R - $120
Display: Acer X223Wbd 22" - $170 free ship
Anyone have the Sonata III? It became my top choice when I realized for $100 it comes with an adequate PSU and has free shipping. I'm just hoping it won't get too hot in the summer in TN if I OC that Q6600 (I'm still picking up the Xigmatech HS/F.)
The Earthwatts 500W PSU would be enough for your setup, and the Sonata III case has a slot for one front-mounted 120mm fan. If you're concerned about heat, pick up two 120mm fans -- one for the front of the case, and the other to replace the less-than-acceptable TriCool fan in the rear -- and an aftermarket CPU cooler. (IIRC, the Xigmatek HDT-S1283 can fit inside the Sonata III case, but the HDT-S964 would work just as well for your needs.) We normally recommend the Yate Loon D12SL-12 case fans due to their price.
