I've shot JPEG for years. I'd like to start using RAW. On top of its technical advantages, I think it will "force" me into better workflow habits.
Right now I'm dumping the card's contents manually (copy/paste) into a folder with the 'dump' date in the name. The files stay named IMG_xxxx. Ones I photoshop get _PS tacked on the end of the filename. It bothers me that the Windows preview ignores EXIF and shows half of my photos "sideways". To fix it would be to re-write the JPEG (which I understand lossy+lossy = slight derease in quality).
I'm looking for advice on a better way to do this. Particularly in terms of filenames, proper photo orientation, and which program I should be using to process RAW files. I would probably archive all the RAW files, and output JPEGs of the 'keepers'.
The camera is a Canon 30D. I believe Canon bundles a RAW program but I'm open to other software as well if it will 'streamline' the process. Thanks everyone.
