Advice Requested - 250GB SSD - Price vs Value
Ensign.Fodder
I do not need screaming performance but I am looking for something dramatic over physical disk (7200 RPM) speeds. Looking around $700 +/- some. It is for a IBM laptop to be purchased at a future time so I am not in a rush to purchase, but wanted to get opinions from the [H]ard people of what drives I should be on my short list.
Thanks!
If you need a single drive (laptop) I'd get the Intel 160GB for $415. 250+GB is cost prohibitive right now ($825 for OCZ Vertex) and you're probably not going to need that much space on a laptop. Get an external 1TB drive for movies/music etc.
-J
-J
I will need the space besides 10 years of business documents and databases I do development for clients and I am currently using around 187 of a 320 GB now.
I need it all on the main drive so that my companies backup solution will back the "stuff" up automatically.
Thanks!
Get a latop with 2 HD bays. There are several out there.
That way you can get 2 x 160Gb X25-M's now, then down the road when they get cheaper and you outgrow 320Gb's you can swap out one of the drives for a larger one, while keeping you OS on the other 160Gb drive.
Another good idea but the company laptop is and will be a single bay.
Thanks!
You only have two options for high-capacity SSD at the moment. SSD makes 250gb parts, and Intel makes 160gb parts.
