ALright, here's the quick run-down of what I think I'd need for a wc setup (complete). I'd appreciate if you guys give me some feedback about improving the thing or correcting my mistakes. My main goal is to achieve the best price/performance ratio
1) Waterblock - I dunno, 3 barb like DD RDX or 2 barb one like TDX, can't decide right now between the 2. Any suggestions? Which waterblock u'd use for just about $50? Also, is it safe to have plastic tops on those waterblocks? or should I got for a solid metal one like Swiftech's?
2) pump - Swiftech 650 or DD 12v D4 pump, and any other high-volume pump.. .Do the pumps come with barbs do I need to buy barbs separately and install them into the pump? Any other quality pumps I should consider?
3) radiator+1 quiet fan: 120mm combo would be the sweet spot for a single waterblock setup (I think). Rad is supposed to have barbs already. I'd go for a heatercore but I cant weld the barbs on it anyways.
4) Swiftech MCB-120 Radbox for external mounting of the radiator - I don't want to deal with hard-modding my case. Mounting acessories comes with the radbox kit for $25, including coolsleeves. Works for 3/8"ID tubing, might be a problem (?) for 1/2"ID
5) DD bay res - do I need some sort of special cap to close after I fill&bleed the system? I'd go for a T fill&bleed but I am not sure if I can close it properly after I am done.
6) tubing - prolly ClearFlex or Tygon, 1/2" ID or 1/2"OD-3/8"ID, online or in local shops I guess. Should I go for 1/2"ID or 3/8"ID with all barbs being 1/2"OD?
+ a bunch of clamps, metal or plastic - any particular suggestions? where can i get those locally?
+ teflon tape or similar sealants to apply to all barbs before connecting the tubes (local hardware store)
8) distilled water from local pharmacy + anti-algae fluid (online?) + water wetter/zerex from local auto shop
Did I forget anything? Are the pumps I listed good for further expansion in the future? like, if I add a GPU block, will those pump be able to handle it?
Well, there it is... let me know what you think.
