I have a full rebuild en route from New Egg which should arrive on Wednesday. I'm curious if anyone has any general advice for preparing for assembly.So far I've picked up an air duster to keep the area free of debris and some acetone to prep the heatsink.
Is there anything else apart from standard tools I should pick up? This is only my second build, and my last had some serious issues which eventually resulted in system failure (it took three years, but it crashed hard - mostly a PS that wasn't up to the job I think). Sound was also an issue with my old box, so I tried to focus on keeping this one quiet. At any rate, I just want to make sure this one goes more smothly (and quietly).
The machine is:
CHAINTECH NVIDIA nForce4 Ultra Chipset Motherboard For AMD Socket 939 CPU
AMD Athlon 64 3200+, 512KB L2 Cache, Socket 939 64-bit Processor
ZALMAN CNPS7000B-AlCu Aluminum + Copper CPU Cooler for Socket
Arctic Silver Premium High-Density Thermal Compound, Model "Ceramique"
Corsair Value Select Dual Channel Kit 184 Pin 1G(512MBx2) DDR PC-3200
XFX nVIDIA GeForce 6800 GT Video Card, 256MB GDDR3, 256-Bit, Dual DVI/TV-Out
Hitachi 160GB 7200RPM SATA Hard Drive
Lite-On 16X, DVD Dual Layer DVD+/-RW Drive
Samsung Black 1.44MB 3.5inch Floppy Disk Drive
Thermaltake SOPRANO Black Middle Tower Case With X type side panel
E-POWER "Tagan" Series 480W Power Supply
Dynatron System Exhaust Blower fit to PCI Slot
Link Depot 18-inch 2 Connector Floppy Cable (Blue)
Link Depot 18-inch 3 Connector IDE Cable (Blue)
Ortek SKB-2500 Slim MultiMedia Keyboard USB 103 keys w/ 2 ports USB hub
Microsoft Black IntelliMouse Optical Mouse
Sandisk Cruzer USB Mini FlashDrive 512MB
The machine is:
