sitalchauhan
- May 30, 2006
I have just done extensive searching for the best wireless router, but I am getting conflicting views. Please could somebody recommend me a .g router with the following requirements?:
1) Needs to have a good range so can reach from ground floor into my loft bedroom
2) Needs to be easy to set up as this will be my first router, so I am very unsure about all the ports stuff yet.
3) It HAS to be VERY compatiable with bittorrent as bittorrent is often running on at least 2 computers in the network.
The 2 popular routers seem to be the Linksys WRT54G (easy to set up, but not very good with bittorrent apparently?) and the D-Link DGL-4300 (looks more advanced and hard to set up, but apparently best performance. Not sure about bittorrent compatiability though).
Please could somebody clarify if either of these has problems with bittorrent, and if they are hard/easy to set up?
If anybody has a router that they are happy with that meets the 3 main point I require and they have no problem with bittorrent, I would be very grateful if you could post the model.
Many thanks for the help,
Sital
Sital
