A year ago, I came to this forum for advice on which components to use to build my PC. The result was great and I built a solid system and never regretted anything.
I just moved and during the move, the wifi antennas of the motherboard became loose (I think beyond reasonable repair) and now it will not catch a wifi signal. =(
So I'm looking to change the motherboard with something similar, but ATX.
I still have all the components in the original thread, so I'm looking for something that will work with those.
I would like the extra room to add more hard drives. Also since I'm going bigger, I'm assuming a good solution for my wifi situation would be to just buy a good wifi card? If so, any recommendations?
Thanks again for all the help!
