rottweiler
- May 13, 2000
Ok, so I probably made a mistake by doing this, but please help me fix it.
I currently have 2 200GB SATA drives in raid-0.
This is my main drive which has my OS.
After seeing my laptop harddrive possibly die, and my Sister just said her harddrive died, I don't want to take the chance of losing all my data if 1 drive fails.
So, my plan is to get 2 more of the same drives and have a raid 0+1 (I think) for a full mirrored backup.
Is this a decent option?
Or should I buy a 36GB Raptor to use as my OS drive?
Also if a 0+1 raid is a good option, then how difficult will it be to set it up without losing data?
My plan after talking to a friend was to setup the 2 new hard drives in raid-0 on a new controller (my mobo only supports 2 sata drives).
Then copy the data from my current raid-0 onto them, I guess using ghost or something?
Then add my current drives to the controller as a mirror of the other drives on it.
Then boot of the controller.
Will this work?
Or does adding a mirror require a format?
Are there any options I'm missing?
Thanks in advance,
Ted
Will this work?
Thanks in advance,
Ted
