Advice on powerful yet cheap build -- Intel only ---
phobic
My friend's laptop just died and she's been worrying me about helping her build a PC. I could easily whip something up in minutes but she refuses to buy anything by AMD (because her brother told her they suck or something... :rolleyes: ). Anyway, I've been teaching her the basics of putting a PC together and after a few weeks on Newegg she's thinking about this system.
CASE (She only wants black and front panel firewire/USB ports are a must)
AeroCool Magic 3D-BK Black Steel ATX Mid Tower Computer Case - Retail -- $59.00
http://www.newegg.com/Product/Product.asp?item=N82E16811196007
CPU
intel Pentium 4 505J Prescott 533MHz FSB 1MB L2 Cache LGA 775 Processor - Retail (2.66Ghz) -- $129.55
http://www.newegg.com/Product/Product.asp?item=N82E16819117042
MOBO
ABIT AA8 Socket T (LGA 775) Intel 925X ATX Intel Motherboard - Retail -- $122.00
http://www.newegg.com/Product/Product.asp?item=N82E16813127180
VIDEO CARD
SAPPHIRE 100120 Radeon X300SE HyperMemory 128MB DDR HyperMemory (32MB Onboard VRAM) DDR PCI Express x16 Video Card - OEM -- $48.00
http://www.newegg.com/Product/Product.asp?item=N82E16814102539
HDD
Maxtor DiamondMax Plus 9 80GB 7200 RPM IDE Ultra ATA133 Hard Drive - OEM -- $55.00
http://www.newegg.com/Product/Product.asp?item=N82E16822144132
RAM
CORSAIR ValueSelect 1GB (2 x 512MB) 240-Pin DDR2 SDRAM Unbuffered DDR2 533 (PC2 4200) Dual Channel Kit System Memory - Retail -- $83.55
http://www.newegg.com/Product/Product.asp?item=N82E16820145526
DVD/CDRW
NEC Black IDE DVD Burner Model ND-3540A - OEM -- $45.99
http://www.newegg.com/Product/Product.asp?item=N82E16827152047
Total with cables and other doo-dads comes to $580. She's getting an LCD monitor but she's not sure what brand/style yet. I honestly don't think she needs all this for web surfing/emails/basic photoshopping but she wants some future proofing in case she wants to uprgade (to what, I don't know). It's her money though. :)
We're pretty much limited to Newegg since we're stationed in S. Korea and don't trust too many other companies shipping here. Plus it only takes 5 days for Newegg to get stuff here... which is amazingly fast. At any rate, any help, tips, or suggestions will be appreciated.
With her purposes, I would ditch one of the 512 sticks of ram and use that money toward a more spacious hard drive. 512 is all you really need if you aren't seriously gaming/video editing and she would definately reap the benefits of an extra 80-120 gigs of drive more for her uses. 512 can still run games like hl2 perfectly fine.
160gb might seem cavernous, but if you have it, you WILL fill it up :). It's one of those things.
Also not sure if you have to go pci-express. I'm willing to bet she can save 50-100$ if she went integrated video. She isnt doing much "future proofing" by going pci express now because any meaningful upgrade after this setup would mean a new socket type (i.e. a new mobo) and a better vid card anyay. the x300 really won't justify 60$ over integrated graphics, especially with the GF4-powered chipsets out right now. The only real difference would be the ability to run DX9 games, but with an x300 she wont be able to enjoy those much anyway.
I would also stick with DDR400, though its her choice.
Take my advice and you she can probably save in the neighborhood of $150 with virtually no loss in performance. She might not think of it as "future proofing", but it is- $150 saved now is $150 more that can be spent later.
Great, thanks. I'll modify her wish list and let her know.
Well what size LCD does she use?
If that 19inch Fuji LCD 12ms is still on sale get that. The Nec/Hyundai is also a great monitor, and then the Samsung for a bit more is good.
I cant comment all that much on the p4 system, i would much rather go AMD but o well:)
I have a few suggestions on the hardware however.
1 - Case - That doesn't come with a PSU so figure another 50 or so for a qood quality PSU. THe guestions i have is does she have any facination with that case? Its a very cheap case inside. I would rather go with a Antec Solutions Quiet case. 2 models they have, one with out the door and one with the door. Both under 80 bucks with a 350watt PSU. Easy to work in, great cooling, very quiet. Just a suggestion
2 - Harddrive - Go SATA, the SATA 80 gig WD use to be actualy 1 buck cheaper then the PATA. No real performace gain, but just 1 wire to hide, and more recent tech, again just a suggestion no real harm.
I would just order AMD gear and slap a Pentium sticker on it she wouldn't know :)
But yeah a Sempron setup would run about 450 with 1gig and onboard with a 80 gig. Would be about 600 with the same + Radeon 9800 or comparable :)
The aa8 is way overkill. Get her either a 915g or a xpress200 mobo. That way, you can save on the mobo AND ditch the video card. Also, the money saved can be invested into the HDD/Monitor/saved for something not computer related.
